bizarre power window problem
Old Jul 7, 2006 | 11:37 AM
meem's Avatar
Elder Member
Default bizarre power window problem
my passenger window will only go up with the passenger window switch (and does so 100% of the time). all other operations work correctly from the driver's side (driver window up/down, passenger down), 100% of the time.
i suspected the switch and replaced it, but the problem persists. i have checked all the connections in the driver's side door and they all seem good. vag-com reports no codes.
anyone have any ideas?
Old Jul 7, 2006 | 12:07 PM
sonus's Avatar
Default so the problem is...the passenger window won't go down using the passenger switch?
or that it won't go up using the driver switch?
Old Jul 7, 2006 | 12:08 PM
TTagz's Avatar
Senior Member
I'd check where the wiring from the driver's side ties in to activate the motor
Old Jul 7, 2006 | 01:17 PM
meem's Avatar
Elder Member
won't go up using the driver's-side passenger switch.
Old Jul 8, 2006 | 02:26 AM
QS -'s Avatar
Default I would also look at the contacts on the 'driver's side - passenger window switch'
make sure that the wiring for the window switch harness/plug is unmolested, and that you are getting good contact w/ the switch.
and like TTagz said, check the wiring (esp in the doors' joints), as they run driver - passanger side.
Old Jul 8, 2006 | 08:46 AM
meem's Avatar
Elder Member
thanks guys, i will check these out and report back
Old Jul 10, 2006 | 11:16 AM
kodeTT's Avatar
Elder Member
Default did you ever find out what the problem was? switch? or wire?
i'm having the same issue with mine.
Old Jul 10, 2006 | 04:24 PM
meem's Avatar
Elder Member
Default definitely not the switch, but i haven't had a chance to ...
check into the wiring. i'll let you know.
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 10, 2006 | 04:41 PM
kodeTT's Avatar
Elder Member
Default so its still broken? mine is all the way down...so i really need to get it fixed soon.
otherwise, can't really drive it anywhere.
Old Jul 10, 2006 | 05:20 PM
meem's Avatar
Elder Member
Default yours doesn't go up via the switch on the passenger side?
sounds like a different problem than mine, then.
