Shifter and Gear stuck problem
Old Jul 7, 2006 | 12:42 PM
roro's Avatar
New Member
Default Shifter and Gear stuck problem
My TTQ 180 is stuck in 2nd or 3rd gear. When I depress the clutch, the shifter moves into each gear groove but the gears don't change.
I had just put the car into 1st and then either 2nd or 3rd while driving and noticed that the shifter **** became elevated about 1/4 inch from it's original height. I thought this felt unusual so starting depressing the clutch and down shifting, but nothing was biting.
Any ideas? Do you think it is a linkage issue, clutch, or bad transmission?
Old Jul 7, 2006 | 01:01 PM
02TTK04's Avatar
Member
Check the shifter linkage first. Easy to check, sort of under the airbox.
Old Jul 7, 2006 | 02:29 PM
roro's Avatar
New Member
Default Re: Check the shifter linkage first. Easy to check, sort of under the airbox.
what should i be looking for. i saw some posts about adjusting the linkage under the hood. How will i know it is a linkage problem under the hood?
Old Jul 7, 2006 | 02:32 PM
02TTK04's Avatar
Member
If that is the problem then they will probably not be attached or very loose.
Old Jul 7, 2006 | 02:35 PM
roro's Avatar
New Member
is it common for the linkage to become detached or loose over time?
Old Jul 7, 2006 | 02:54 PM
02TTK04's Avatar
Member
Maybe slightly out of adjustment, but not common to become detached.
Old Jul 7, 2006 | 03:12 PM
roro's Avatar
New Member
Default if i have to adjust the linkages, do you know how I would get my car in neutral from 2nd before....
I adjust. The bently manual says I would need to start in netural first, but unfortunately part of my problem is the gear in stuck in 2nd.
Old Jul 7, 2006 | 03:16 PM
02TTK04's Avatar
Member
You need to get in there and look at the linkage first. You have to find the problem first.
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 7, 2006 | 03:28 PM
roro's Avatar
New Member
ok, i'll check it out. do you mind if i ping you later
Old Jul 10, 2006 | 06:31 PM
roro's Avatar
New Member
Default the linkage looks ok and not loose
when the car is off, i'm able to move the shifter into the different shift positions including reverse. when the shifter is in neutral, i can directly move the linkage by hand somewhat
when the shifter is engaged in one of the shift positions, the linkage appears to be locked and can't be moved by hand.
What do you think?
DaveO121872
Mar 5, 2014 04:44 AM
JT078
Sep 22, 2005 11:56 AM
tristan325
Jun 18, 2005 01:55 PM
LUCIFA
Nov 4, 2001 06:16 AM
VladN
Jun 21, 1999 06:52 AM
