A MAP sensor wouldn't need to be in the air flow would it?
<img src="http://images18.fotki.com/v339/photos/9/910849/3688904/IMG_4030-vi.jpg">
Thanks,
Trent
Any way the 42DraftDesigns part could help you out? It appears your Del Rio was bored out for the larger VW MAP instead of the Audi/TT diamter.<ul><li><a href="http://www.42draftdesigns.com/18tmapsensors.htm">http://www.42draftdesigns.com/18tmapsensors.htm</a</li></ul>
Doesn't need to be in the stream..<ul><li><a href="http://www.42draftdesigns.com/18tmapsensors.htm">MAP Bung from 42 draft design</a></li></ul>
Trent
<b>Applications</b><i>
This sensor is used to measure the
absolute intake-manifold pressure. On the
version with integral temperature sensor,
the temperature of the drawn-in air flow is
also measured.
</i>
<b>Design and function</b><i>
The piezoresistive pressure-sensor element
and suitable electronic circuitry for signalamplification
and temperature compensation
are mounted on a silicon chip. The
measured pressure is applied from above
to the diaphragm's active surface. A
reference vacuum is enclosed between the
rear side and the glass base. Thanks to a
special coating, both pressure sensor and
temperature sensor are insensitive to the
gases and liquids which are present in the
intake manifold.
</i>
<b>Installation information</b><i>
The sensor is designed for mounting on a
horizontal surface of the vehicle's intake
manifold. The pressure fitting together with
the temperature sensor extend into the
manifold and are sealed-off to atmosphere
by O-rings. By correct mounting in the
vehicle (pressure-monitoring point on the
top at the intake manifold, pressure fitting
pointing downwards etc.) it is to be ensured
that condensate does not collect in
the pressure cell.</i>
so to answer your question, i dont think it matters in your case.<ul><li><a href="http://www.modifieda4.com/web/archive/sensoren.pdf">see page 34...right click save-as please.</a></li></ul>
