Help! Installed HR springs / Bilstein sport shocks. Talked to the dealer about alignment....
Old Aug 7, 2006 | 12:48 PM
T Audi T's Avatar
Default Help! Installed HR springs / Bilstein sport shocks. Talked to the dealer about alignment....
He says I need to know the specs to have it aligned. Standard specs don't apply due to the lowering. I took measurements before I lowered it but not since. I am guessing it dropped between an inch and an inch and a quarter.
Is there a specification standard as far as lowering is concerned?
This all sounded a bit strange to me.
I also have purchased rear camber adjustment bushings. Should I install these or have the dealer do it. I plan on doing it before I take it to them.
Old Aug 7, 2006 | 12:55 PM
1 Mean TT's Avatar
Default the specs that the dealer was thinking about is probably that thing>>>>
that doesn't allow for rear camber adjustment. It should be the same specs for a non lowered TT. He'll just have to adjust the camber using your supplied bushings.
JohnLZ7W's Avatar
Default Most folks aim to get it back to near factory specs but
you'll need some extra camber adjustment either adjustable arms or kmacs to get it back in spec.
Old Aug 7, 2006 | 02:20 PM
T Audi T's Avatar
Default I discussed rear camber adjustment with him and told him that I would be installing
adjustable camber bushings. He still insisted that I needed alignment specs.
Old Aug 7, 2006 | 02:27 PM
JohnLZ7W's Avatar
Just tell him to align it to factory specs.
Old Aug 7, 2006 | 02:28 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Tell the dealer to use the Audi "Sport" setting.......
Old Aug 7, 2006 | 03:07 PM
T Audi T's Avatar
Default Just to satisfy my own curiosity, What is the difference between "sport" setting and stock setting?
What is it that changes that would require different geometry?
Old Aug 7, 2006 | 03:09 PM
JohnLZ7W's Avatar
Default IIRC the sport setting basically allows for more camber
mainly because the sport suspension is slightly lower than stock and does not include any additional camber correction. So, rather than fix the problem Audi just widens the spec so that the camber that the sport suspension causes is now considered in spec.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 7, 2006 | 03:17 PM
TTinCT's Avatar
Rest In Peace
Default yep...here they are...>>>
This sets the car up nicely. My setup is the classic Bilstein/Eibach suspension...
<img src="http://images8.fotki.com/v160/photos/8/89907/1913901/wheelsettingszoomed-vi.jpg">
Old Aug 7, 2006 | 03:33 PM
T Audi T's Avatar
Default By more camber do you mean negative camber? Hmmm... Does that mean:
that with the use of adj. camber bushing I should be able to get back to the original spec and therefore should?
