paging AU-297: I saw (but didn't track) your post on ride height results
Old Aug 7, 2006 | 03:49 PM
Russ Scott's Avatar
Default paging AU-297: I saw (but didn't track) your post on ride height results
with the S-Line springs and Bilstein Sports. Less than a 1/2 inch drop? This suggests that the S Line spring is functionally equivalent to the Eibach Pro Spring, not shorter. The ride height difference between your previous set and this one is very likely caused by the high pressure gas charge in the Bilsteins vs the low pressure (or no pressure) construction of the OEM S-Line shocks. It should settle a little more...
Old Aug 8, 2006 | 09:33 AM
353/s/'s Avatar
Default Hey Russ... sorry for the delay... I'll post them next week. I want them to settle first.
I go in for a alignment on Tuesday. I'll take some pics... My rear springs aren't seated properly... so I'm getting that fixed too on Tuesday! Grrr!
Old Aug 8, 2006 | 11:28 AM
Russ Scott's Avatar
Default this might help... a thread on rear spring indexing
<ul><li><a href="https://forums.audiworld.com/tt/threads/416643.phtml#1406429">push here</a></li></ul>
Old Aug 8, 2006 | 11:02 PM
353/s/'s Avatar
Thanks Russ... I try to reposition them tomorrow after work... I'll let you know how it goes!
LIRS6
RS 6 Discussion (C5)
11
Jan 15, 2007 03:42 PM
caster
17
Mar 22, 2004 06:33 PM
dereliked
Nov 23, 2002 05:10 AM
Raistlin
Jul 29, 2002 04:28 PM
