Need a quick Vag Com scan, for headlight adjustment
I am facing a little issue with my ECS tuning tie-bars, they installed the adjustment right where the headlight level sensor is going... bright idea ! anyway, now my headlights are aiming so low , I can't see more that 15 to 20 feet ahead and this with no beer.
I did search but I would like to have the measuring block value for the rear sensor for someone lowered with KW, set at the lowest position on the perch.
That would help a lot to try to optimize this situation since I do not want to compensate the adjustment using the front one, if possible.
Thanks.
EvilTT
<a href="http://www.ross-tech.com/vag-com/cars/xenonalignment.html">Ross -Tech page for more info</a>.
Yes, ther eis a measuring block, it is on the group 002
BTW, seeing your bumper, you must be in Canada ? where are you located ? I am in Montreal
