I'm thinking about installing an FMIC, but I'm having second thoughts......
To me, It looks like trading an FMIC for the two SMICs is not much of an improvement since the surface area (not frontal area) of the two SMICs is comparable to that of the FMIC. I don't see much of an improvement other than esthetics. Not only that, but adding the IC heat to the front of the coolant & A/C radiators can't be good for those systems.
What would really make sense to me would be to keep the SMICs and ADD the FMIC between them. The combined cooling power should be increased significantly. I haven't been into the guts of the system yet but it looks like the exhaust of the first SMIC (and the inlet to the second SMIC) could be routed forwards into the inlet (outlet) of an FMIC with revised end caps rotated 90 deg backwards to mate with the SMICs.
Has anyone ever considered this concept, or I'm I missing something basic.
BlueChip
The FMIC does have more surface area overall, and being in the direct air path it gets more flow through it. Schwing has states that exit temps are very near ambient, so you can't really get much/any better.
As far as worrying about adding heat to other systems... No one has reported a problem there. Your thermostat will keep the water path open more often to take care if it. Also, if you add an oil cooler as well, that burden comes off of the water cooling path all together - maybe a net "-"...
Trust us...An FMIC is a big improvement. Audi spec on the dual SMIC's is 80%. Measured efficiency with the FMIC is 93%. Due to the size, it never really gets hot enough to affect cooling. It's really a Heat sink, not a radiator per se...
I was truly surprise how much more peppy my car was after the FMIC install. Everyone says it doesn't add power, it keeps you from losing it... Well, I suspect you lose power A LOT, because I really notice the car being more powerful, more of the time. There are few mods I can truly feel make a difference, this one does it!<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/engine_and_drivetrain/oct_front_mount/">O.CT FMIC Install Fotki</a></li></ul>
Is there a site where the cooling effect of the two SMICs is compared to an FMIC. I sure would like to know how much bang I'm getting for my buck.
Day to day driving the FMIC will not help much. Maybe on a really hot day in city traffic, but then not much hp is needed.
I have found the biggest help is on autocrossing where you make a really hot 60 second run, then sit. This is where you get the great heat soak and this is where the FMIC really helps.
It's a very extreme situation and probably will never be an issue on a normally modded car. And I wouldn't doubt the Del Rio gives up a bit in air cooling because of it's smaller size. I guess I'll see.
I think I'm still trying to justify the smaller Del Rio FMIC to myself. It's kinda working.
Trent
BlueChip
