Any problems with running 245/40/18 on a TT? I know its not OEM, but would it do any damage?
Old Aug 7, 2006 | 07:26 PM
maaliish's Avatar
Old Aug 7, 2006 | 07:40 PM
ePuFFy's Avatar
Default Your speedo will be slower, and your tires will look beefy... I think that's it.
i'm assuming you're talking about stock width wheels...
Old Aug 7, 2006 | 07:53 PM
maaliish's Avatar
Default yep stock width wheels. (7.5) I wasn't sure if it would fit at all and worried that
it might effect performance to a great degree and even worse cause problems with haldex. I would love the look though so if I can fit em with no major worries - I'd get 'em.
Old Aug 7, 2006 | 08:05 PM
XCLR8TT's Avatar
Senior Member
The only thing critical with the Haldex is that the rolling diamaters are equal on all 4 corners.
Old Aug 7, 2006 | 08:32 PM
ePuFFy's Avatar
why would you go that big though?
Old Aug 7, 2006 | 08:33 PM
maaliish's Avatar
love the look of nice fat tires :-)
Old Aug 7, 2006 | 08:34 PM
TTagz's Avatar
Senior Member
check the tire specs, most require a minimum 8" wheel for anything over 225
Old Aug 7, 2006 | 08:35 PM
maaliish's Avatar
Default gotcha. Thank you. I thought I've seen posts stating that there was a max/min overall diameter for
quattro, but maybe it was for the torsen based system.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 7, 2006 | 08:38 PM
maaliish's Avatar
Default Thats exactly what I found, but I thought I'd check here. I couldn't even find a 235 tire for a 7.5
rim but I distinctly recall it being recommended on this board. LOL now I'm even more confused. So if tirerack says 8" minimum then thats the way it is? I seem to be getting contradicting responses.
Old Aug 7, 2006 | 08:44 PM
JohnLZ7W's Avatar
Not sure where the contradicting info is, I've always seen 8" minimum for a 245.
