Please help decipher coding from VAG-COM (I just got it!)
Old Aug 8, 2006 | 12:03 PM
JustAdam's Avatar
Default Please help decipher coding from VAG-COM (I just got it!)
Tuesday,08,August,2006,14:26:49
VAG-COM Version: Release 607.2-UD
Chassis Type: 8N - Audi TT
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine
Part No: 8N0 906 018 T
Component: 1.8L R4/5VT G 0003
Coding: 06610
Shop #: WSC 01236
1 Fault Found:
17947 - Clutch Pedal Switch (F36): Implausible Signal
P1539 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Part No: 8N0 907 379 C
Component: ABS/EDS 20 IE CAN V003
Coding: 13504
Shop #: WSC 01236
No fault code found.
Address 08: Auto HVAC
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
Address 15: Airbags
Part No: 8N8 909 601
Component: Airbag Front+Seite 1005
Coding: 10102
Shop #: WSC 01236
2 Faults Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
32-00 - Resistance too High
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
Address 17: Instruments
Part No: 8N1 920 930 E
Component: KOMBI+WEGFAHRS. M73 D09
Coding: 07244
Shop #: WSC 02116
Address 22: AWD
Part No: 02D 900 999 X
Component: HALDEX LSC ECC 0011
Address 35: Centr. Locks
Part No: 8N8 962 267 A
Component: Central Lock/Alarm D04
Coding: 15980
Shop #: WSC 01236
4 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
01617 - Please Check DTC Memory of Interior Monitoring
35-10 - - - Intermittent
Address 45: Inter. Monitor
Part No: 8N8 951 177 A
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
35-00 - -
Address 55: Xenon Range
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
1 Fault Found:
01539 - Headlights Not Adjusted
35-00 - -
End --------------------------------------------------------------------------------------------------
Tuesday,08,August,2006,14:54:17
Address 01: Engine
Coding: 06610
Shop #: WSC 01236
1 Fault Found:
P1539 - 35-00 - -
Coding: 13504
Shop #: WSC 01236
Coding: 00140
Shop #: WSC 01236
Address 15: Airbags
Coding: 10102
Shop #: WSC 01236
Coding: 07244
Shop #: WSC 02116
Address 22: AWD
Coding: 15980
Shop #: WSC 01236
4 Faults Found:
35-00 - -
35-00 - -
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
35-00 - -
Coding: 00010
Shop #: WSC 01236
1 Fault Found:
35-00 - -
P.S. Disregard the airbag issue as it is already fixed - but the rest keeps coming back even though I have been clearing the codes!
Anyone help?
Old Aug 8, 2006 | 12:13 PM
JohnLZ7W's Avatar
most of that looks like it's from the alarm being triggered
Old Aug 8, 2006 | 12:22 PM
JustJeff's Avatar
Default Have you recoded the locks for 15MPH locking, and/or one-button up/down? If so, these codes will
continue to appear.
Old Aug 8, 2006 | 01:14 PM
JustAdam's Avatar
Both - so I should just ignore these?
Old Aug 8, 2006 | 01:33 PM
JustAdam's Avatar
And what about the clutch code?!?
Old Aug 8, 2006 | 02:06 PM
JustJeff's Avatar
Default that's an odd one. There are 2 relay contacts on the clutch, a Normally Open and a Normally Closed
It may be a relay, but it's doubtful, or your car would not start.
Keep monitoring it is all I can say.
Old Aug 8, 2006 | 03:22 PM
JustAdam's Avatar
Default More backround, I think we are getting somewhere ............. >>>>
I have had my clutch replaced recently, not sure if that would make a difference.
More than that though, I had noticed about 3 months ago (even before TT-west) that I did not have to push the clutch in to start my car - not sure if that really matters or not, I dont really care one way or the other.
Should I just forget about it?
Old Aug 8, 2006 | 03:56 PM
JustJeff's Avatar
that is the problem, the switch is bad on the clutch pedal.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 8, 2006 | 05:16 PM
JustAdam's Avatar
Thanks Mr. "J"
WECoyote-SuperGenius
Sep 10, 2006 12:40 PM
NY / NJ / CT Discussion
11
Sep 10, 2006 02:11 AM
GlacialBass
Sep 16, 2005 02:43 PM
uber_ar
Audi allroad
18
Aug 26, 2005 06:10 PM
