I have a lot of kluncking at low speeds coming from the drivers side, I started to get this problem
Old Aug 8, 2006 | 02:55 PM
polishadonis's Avatar
Default I have a lot of kluncking at low speeds coming from the drivers side, I started to get this problem
after the KW coilovers were installed. Could it be the CV boot? I changed the CV boot but I saw a lot of grease around so the clamp was tightened more. I still think there is enought grease becuase there was tons of grease in it when it was replaced 2 weeks ago, maybe 1/2 of a cup of grease per cv boot. Any thing else I shoud look for, like a bushing?
Thanks for any suggestions ahead of time, it is driving me crazy. And by the way there is no noise on the passenger side.
Old Aug 8, 2006 | 03:01 PM
aTTicism's Avatar
Are the left front wheel bolts tightened and torqued to 90 ft/lbs?
Old Aug 8, 2006 | 03:31 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Undo everything you did..>
and re-do it. You screwed something up. "what" is the question...
Old Aug 8, 2006 | 04:43 PM
jackTTar's Avatar
Member
Default Check to make sure the strut is torqued down correctly...
so that the strut bearing and other top side components are not loose.
Old Aug 8, 2006 | 05:33 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default You're probably on to something there, as torqueing the KW's is rather difficult with nothing to
hold the shaft from turning. There is an ajustment screw at the top where the OEMs have the allen bolt.
Old Aug 9, 2006 | 09:00 AM
maaliish's Avatar
I'm betting on strut bearing and associated nuts.
Old Aug 9, 2006 | 11:20 AM
Checking it out today...
marshap1
Wheels & Tires Discussion
Sep 6, 2015 12:21 PM
Pushbutton_auto
Jun 5, 2010 08:21 PM
DeepCover
Oct 19, 2008 08:03 AM
AmarilloA4
Jun 30, 2005 06:23 AM
Brilliant_A4_99
Apr 12, 2005 11:43 AM
