Does anyone here run 19" wheels staggered on their Quattro?
Old Aug 9, 2006 | 08:18 AM
sloduck's Avatar
Default Does anyone here run 19" wheels staggered on their Quattro?
I'd like to hear your input good and bad.
TIA
Old Aug 9, 2006 | 08:44 AM
aTTicism's Avatar
Default Do a search.>>>
The TT is basically a front wheel drive car and quattro comes into play when needed. The front track of a TT is purposely wider than the rear track by design. So, if you widen the rear track with a staggered setup, you increase understeer. To keep from harming the Quattro unit the circumference of tires needs to be kept the same. Audi recommends the same size wheels and tires on all four corners for the TT. Check that in your Owner's Manual.
Old Aug 9, 2006 | 08:59 AM
ar design's Avatar
Yes, you can run 19" staggered just fine, just probably isnt the best for Auto-X
louiestt
17
Jun 4, 2006 12:28 PM
ajp_984
19
Mar 8, 2006 08:56 PM
Basttion
Feb 7, 2006 10:52 AM
problemchild
Apr 9, 2003 01:18 PM
