Anyone have a picture of where the Turbo Coolant after-run pump is located?
Old Aug 10, 2006 | 09:23 AM
Sully's Avatar
Member
Old Aug 10, 2006 | 09:25 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default It's always in the....>
FAQ..<ul><li><a href="https://forums.audiworld.com/tt/msgs/1522043.phtml">SparTTan's write-up..</a></li></ul>
Old Aug 10, 2006 | 09:26 AM
JohnLZ7W's Avatar
is it in the same place on a 180?
Old Aug 10, 2006 | 09:35 AM
Sully's Avatar
Member
Default Sorry, I should know better. Guess I am lazy...>>>
at any rate, I am sure this is where I have been leaking coolant lately...at least I hope this is the simplest route to a solution.
I should be a little more savvy on using the FAQ more often. Thank you though Steve for providing the helpful thread on this. It's greatly appreciated.
Old Aug 10, 2006 | 10:16 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Oh, Whoops! NEVERMIND Scott.....>>
You don't have one....
(It's hard for me to keep up with hundreds of TT-peeps and their engine combos..!)
Old Aug 10, 2006 | 10:20 AM
GorTT's Avatar
but I WANT one!
Old Aug 10, 2006 | 10:25 AM
JohnLZ7W's Avatar
Well, that's an easy fix for the leak then
Old Aug 10, 2006 | 10:27 AM
Sully's Avatar
Member
Then I have to find the easy place where it's leakin'
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 10, 2006 | 10:29 AM
JohnLZ7W's Avatar
Should be pretty easy, the pink stuff usually leaves a nice crusty trail
Old Aug 10, 2006 | 10:32 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Where is it leaking?....>
Front right side is often the water pump...
