break bleed
Old Aug 11, 2006 | 05:20 AM
federal's Avatar
Default break bleed
can anyone direct me to a wrie up on how to changing break fluid in tt 1999 - thanks .
Old Aug 11, 2006 | 05:43 AM
Scenic Driver's Avatar
Bentley Manual + Motive Power Bleeder
Old Aug 11, 2006 | 06:17 AM
RoberTT-WWCD's Avatar
Default Have a friend handy if you don't have a power bleader...>>
Start by toppiing off the reservior with fresh fluid.
Starting at the passenger rear, have your friend press and hold the brake pedal.
Loosen the bleed screw until the pedal is to the floor. Then close the screw.
Have your friend release the brake pedal and press the pedal a couple time and hold.
Repeat procedure until you see new brake fluid. (Make sure you keep the reservior topped off.)
Once that wheel is done, move to the driver's rear and repeat.
Then off to the passenger front followed by the driver front.
After all is done, top off the reservior and make sure sure you have good pedal.
Test drive.
Old Aug 11, 2006 | 06:48 AM
oc_tt's Avatar
Just don't "brake" it!
Old Aug 11, 2006 | 06:52 AM
Dont forget the clutch needs to be done as well.
Old Aug 11, 2006 | 10:31 AM
JohnLZ7W's Avatar
Doesn't need to be done and I've never seen instruction on how to do it either
ImQuattro®
Audi Original "S" Cars
Dec 31, 2008 03:55 AM
muzikmann
Dec 2, 2007 07:09 PM
N X B 3
Mar 31, 2005 05:57 AM
00zero
Aug 9, 2004 07:34 PM
Gordan T.
Apr 16, 2003 12:43 PM
