omg! $700 for glovebox!
Old Aug 11, 2006 | 01:37 PM
wiggle's Avatar
New Member
Default omg! $700 for glovebox!
Glove box latch comes off and drops into floorboard. Anyway to still get it open? Also,
dealership says $700+ to replace. Any alternatives? TIA
Old Aug 11, 2006 | 01:40 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Fix it!
Gett Da Nett has posted fix it help here....Do a search!
As far as opening it, pop off the panel on the right of the dash (Mirror image of the fuse box cover) and push the pin in with a pick..
Old Aug 11, 2006 | 01:43 PM
wiggle's Avatar
New Member
thx Schwing / searching now
Old Aug 11, 2006 | 01:46 PM
stilljester's Avatar
Member
If you need someone to fix it I can help you out. I've fixed a bunch now
Old Aug 11, 2006 | 02:07 PM
sonus's Avatar
Default Here's my write-up w/pics based on GeTT da NeTT's instructions
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1417052.phtml">Pictures of my Glovebox fix as requested</a></li></ul>
Old Aug 11, 2006 | 02:18 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
A write-up on this belongs in the FAQ...
Old Aug 11, 2006 | 02:31 PM
sonus's Avatar
Its been added
Old Aug 12, 2006 | 05:17 AM
Astronut's Avatar
Default I used this fix mine w/o the speed nut
I just drilled and tapped the plastic. It's held up fine. I lost the lower plastic pin though.
You should be able to open the glove box just by pressing the metal tab here
<img src="http://static.flickr.com/40/81728278_5e095437e1_o.jpg" alt="Broken Glove Box" />
to one side (right I think). Use a screwdriver if you can't get a finger in there.
 Pouria Savadkouei
 Michael S. Palmer
Mrider
Aug 24, 2009 04:44 AM
Xiety
Jul 10, 2004 03:11 PM
Tenacious C
Nov 2, 2003 05:51 AM
yamahapro361
Aug 30, 2003 05:39 PM
economisTT
Mar 23, 2002 07:46 AM
