DEFCON 2, strut bearings and ball joints done!... car is ready for the road, see you in a few hours
Old Nov 17, 2006 | 10:52 AM
HACK THS's Avatar
Default DEFCON 2, strut bearings and ball joints done!... car is ready for the road, see you in a few hours
By the way it took a propane torch and a bunch of new craftsman tools to make it happen, but I got the damn nut off. I think the problem was that when they installed my suspension back in the day they used an impact wrench to install the nuts the first time since they did not know how to make the strut from spinning. Any ways, they are all done!
Also which was interesting, the bearings were totally intact on both sides, the rubber mounts were obviously compressed a decent amount. Thought it was not too bad after 105,000 miles
Old Nov 17, 2006 | 11:31 AM
sonus's Avatar
So how exactly, did you get the strut nuts off? I may be in the same predicament as you.
Old Nov 17, 2006 | 12:20 PM
SparTTan's Avatar
Default Ha, I ran in to the same issue.
The hex key hole on the top of the strut actually stripped in the process. I have a feeling the shop that installed my suspension over-tightened everything. I managed to get everything back together but I hope I never have to get those things off again.
Btw, my bearings were completely fine too, but bushings were compressed. Not too bad though.
Old Nov 18, 2006 | 08:10 AM
HACK THS's Avatar
Default I had to use a torch to heat it up...
I found that the impact wrench was less effective then my pry bar and sockets... it was scary but I put all my weight on that nut, leaning over the engine bay almost. Then poof it came off.
Old Nov 18, 2006 | 08:11 AM
HACK THS's Avatar
exactly how mine was
riotburn
Jun 18, 2009 09:57 AM
John P. (TT 225)
11
Sep 20, 2007 06:46 AM
AudiSport4000
16
Sep 18, 2007 02:15 PM
emmett03
Audi Original "S" Cars
Mar 27, 2005 12:56 AM
