So I just did strut bushings & bearings & brakes all around..still front passenger noise...
Old Nov 17, 2006 | 06:51 PM
VorsprungTT's Avatar
Default So I just did strut bushings & bearings & brakes all around..still front passenger noise...
Clunking noise, thought it was the strut bearings. turns out i was wrong i guess. i put new bearings, rubber & hardware in - no difference.
It's a clunking noise going over any size bumps or when i turn the wheel. Just from the front passenger side...sway bar? It dosn't appear to have plastic sleeves on it...
Old Nov 17, 2006 | 06:59 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Check the sway bar drop link..>>
Those joints go occasionally. When they do.....Clunk!
Old Nov 17, 2006 | 07:01 PM
kodeTT's Avatar
Elder Member
Default probably the swaybar bushing. if you didn't change it yet, you probably should swap it
for some poly bushings. 20mm powerflex bushings.
that's a common noise on TTs. failure of the bushing/plastic sleeve.
Old Nov 17, 2006 | 07:11 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default You can pull the PASSENGER side sway bush in 10 minutes and check if you
have plastic sleeves. If you do, go for poly's...<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/brakes_and_suspension/front-anti-swaybar-/">http://public.fotki.com/mcphill/audi_stuff/brakes_and_suspension/front-anti-swaybar-/</a</li></ul>
Old Nov 17, 2006 | 10:57 PM
sterni's Avatar
Default were would said TT owner purchase such these things?
TIA :-)
Old Nov 18, 2006 | 02:06 AM
I looked earlier tonight, it seems as though its all metal. I'm going to take apart tomorrow
Old Nov 18, 2006 | 04:14 AM
oc_tt's Avatar
Same thing happened to me, I'd assume all the suggestions are right on the money. Next project...
Old Nov 18, 2006 | 04:44 AM
02TTK04's Avatar
Member
Any tears in the cv joint boots?
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 18, 2006 | 05:42 AM
Tech Guru
Default How 'bout the link, listed in the Fotki?
<ul><li><a href="http://www.ttstuff.com/Merchant2/merchant.mv?Screen=PROD&amp;Product_Code=FMPFF3503 20">http://www.ttstuff.com/Merchant2/merchant.mv?Screen=PROD&amp;Product_Code=FMPFF3503 20</a</li></ul>
Old Nov 18, 2006 | 06:02 AM
GorTT's Avatar
Default is that also called >
<center><img src="http://pictureposter.audiworld.com/53277/vfendlink.jpg"></center><p>the "connecting link" (part 18 on illustration 407-11 on Ekta - long thin rod (sorry, still haven't figured out how to post from ekta))? Of course "the actual part may differ...", but there is an apparent 'significant' difference in length. I don't necessarily want these, btw, but curious.
