would rear camber arms be an easier install then a full set of Kmacs??...>>
Which kinda pisses me off cause when I dropped the car off at KMD, I specifically listed on paper to install rear camber adjusters only if needed after the KW's are installed and no adjusters were installed as I was told that it wasn't needed since the TT always had a positive camber.
So here is my alignment sheet from when I got the car back.
Rear Camber:
Initial: Left -3.0 / Right -2.4
Spec Min: -1.8 / Spec Max: -1.2
Final: Left -3.1 / Right -2.4
Toe:
Total: 1.15 / Left 0.40 / Right 0.75
Spec Min: 0.08 / Spec Max: 0.42
Final: Total 1.50 / Left 0.75 / Right 0.75
i just got mine done on Friday...was in and out in an hour. about $105, although you can get it for less at the TireBarn ... mike (liTTespeed) got an AWD alignment for $50-70. they have specials as well.<ul><li><a href="https://www.tirebarnnj.com/TireBarn/">the barn</a></li></ul>
