Anybody got torque specs handy for front and rear suspension? Two installs
Old Nov 18, 2006 | 12:57 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default Anybody got torque specs handy for front and rear suspension? Two installs
going on, but no homework done... Need front "clamp" bolt that holds the lower strut mount, then rear shock bolts...
Old Nov 18, 2006 | 01:22 PM
MarTT's Avatar
Default Here are the rears, getting the fronts now . . .
Secure coupling rod to stabilizer bar.
Tightening torque: 25 Nm
Tightening torques:
Shock absorber to body
Always use new bolts.
60 Nm
Shock absorber to longitudinal control arm
Vehicle must be resting on wheels and have a person seated in the rear seat.
110 Nm
Old Nov 18, 2006 | 01:26 PM
MarTT's Avatar
ygm on the fronts
Old Nov 18, 2006 | 01:29 PM
whodkne's Avatar
Member
Default Who in the hell wouldn't look up specs before doing an install?!
Old Nov 18, 2006 | 01:32 PM
MarTT's Avatar
Ha! Because he knows he has US to bail his butt out!
Old Nov 18, 2006 | 01:39 PM
Tech Guru
Yes, "He" had "YOU" to bail him out... Thanks MarTT!
Old Nov 18, 2006 | 01:54 PM
GorTT's Avatar
Default Regarding noise in the front >
I did have a loose cap securing the piston to the tube on one of my coilovers - that's probably not your issue, but check the drop link bolt connecting to the coilover - that seems like it made noise if not secured properly - can feel tight, but I missed the wrench last time; both of the two fixed, my noise gone.
Also btw, I didn't realize the clamp bolt was a stretch bolt - I need to order some asap; so much for looking up specs!<ul><li><a href="https://forums.audiworld.com/tt/msgs/1577293.phtml">drop link connection</a></li></ul>
Old Nov 18, 2006 | 03:08 PM
whodkne's Avatar
Member
 Pouria Savadkouei
 Michael S. Palmer
arbart
Audi allroad
Feb 15, 2017 04:53 PM
kelisko
Apr 14, 2016 01:25 AM
Badd TT Bone
May 29, 2007 05:52 AM
SteveTT
Mar 1, 2002 08:20 AM
Sean T
Performance and Tuning
Apr 25, 2001 11:26 AM
