Rear brake pistong seized?
Old Nov 18, 2006 | 05:03 PM
gagnu's Avatar
New Member
Default Rear brake pistong seized?
I can't get my passenger side brake piston to compress, the pads were all worn and ate a grove in the rotor, the piston is out an inch or more. No problems with the driver side, pad and rotor look good and I was able to compress the piston without any problems. Is the passenger side piston seized? Would this be covered under Audi CPO? Thanks.
Old Nov 18, 2006 | 05:15 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default I assume you're rotating the piston ..>>
As you try to compress it? This is why the special tools come in handy. If you run the pads down to nothing, the retraction process can be difficult..
Old Nov 18, 2006 | 05:18 PM
gagnu's Avatar
New Member
Yup I broke the one I had and tried another from Autozone, the piston won't move at all.
chenishead
Nov 10, 2008 11:20 AM
Ragdoll
23
Jul 2, 2008 02:21 PM
theonlineguy
Aug 5, 2007 06:24 PM
Seanism (clone510)
May 12, 2005 06:14 AM
John Pal...
Mar 9, 2003 06:37 PM
