What's the preferred setup on suspension?...
Old Nov 19, 2006 | 05:27 PM
TToplessTTs's Avatar
Member
Default What's the preferred setup on suspension?...
Coilovers or separate springs/struts? I have no idea what the difference is other than the Coilovers seem adjustable... But so are some of the struts. The coilovers are slightly more expensive too. I'm considering the H&R coilovers vs. Eibach springs/Bilstein Shocks/Struts.
Oh, I'm also considering the KMAC. Should I do full KMAC or 1/2 KMAC with adjustable arm? Any difference?
TIA.
Old Nov 19, 2006 | 06:06 PM
specialidiot's Avatar
Default tell us what you plan to do with your tt
track, autocross, street? Want a slammed look, or just a bit of lowering and improved performance?
That will lead to the discussion about KMAC/arms
Old Nov 20, 2006 | 04:28 AM
Member
Default It will be used for street performance...
Taking it to the mountains for some driving, but very rare to none on the track. I want the car lowered, but not slammed. I would guess and inch to inch and a half would be lowered enough.
Old Nov 20, 2006 | 07:46 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Save your money then..>>
Eibachs/Bilsteins are an excellent combination that many here run..
Old Nov 20, 2006 | 07:56 AM
Member
Default Thanks... Should I also add the 19mm RSB and
DEFCON bushings? Or is that overkill for my application?
Old Nov 20, 2006 | 08:58 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default 19mm and...>
at least a half set of Kmacs for the rear. Defcons on the front will make for a very nice, responsive package..
TwinTurboTerror
Jan 26, 2005 08:51 AM
sickspeed
Oct 4, 2004 12:13 PM
XTHCX
Feb 5, 2004 05:05 PM
just_a_kid
Jul 15, 2002 12:27 PM
simply J
Apr 10, 2002 06:58 PM
