so how delicate is the haldex system to difference in tire size?
Old Nov 20, 2006 | 03:11 PM
boobiestt's Avatar
New Member
Default so how delicate is the haldex system to difference in tire size?
so as told in prior post my passenger side rear tire is trash and i'm getting an alignment done early next week. i went to price a replacement tire and the salesman at discount tire said they wouldn't put just one tire on my car since its all wheel drive. he was a wrx guy and claimed to have seen cars eat a diff because of the difference in tire size do to uneaven tread wear. so my question to all you more experienced gents is do i need to replace all four or am i safe with replacing just the one?
tia
Old Nov 20, 2006 | 03:15 PM
XCLR8TT's Avatar
Senior Member
Default The salesman is correct. Alternatively, you could order a tire and have it shaved to match from
Tire Rack.<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&url=%2Ftires%2Ftiretech%2Ftechpage.jsp %3Ftechid%3D18">Matching tire on 4WD and AWD vehicles</a></li></ul>
Old Nov 20, 2006 | 03:22 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default At a minimum, replace a pair on an axle. Keep your "good" one for later, if you end up in the same
predicament again.
Old Nov 20, 2006 | 04:48 PM
boobiestt's Avatar
New Member
dam... i guess the question now is should i just go all the way with new wheels too
Audi Junkie
Wheels & Tires Discussion
Aug 9, 2007 08:20 AM
chairman
Feb 20, 2005 10:18 PM
Adrien A4
NY / NJ / CT Discussion
Nov 18, 2004 05:42 AM
Jus Plain Snoopy
Mar 10, 2002 09:38 AM
dt
Aug 31, 1999 02:58 PM
