Help Please: Thick red fluid found on garage floor
Old Nov 21, 2006 | 06:07 AM
EzAudi's Avatar
New Member
Default Help Please: Thick red fluid found on garage floor
Is this indicative of a Transmission leak? How serious is this??
On garage floor under the front passenger side, I found two spots roughly 2" in diameter probably from parking in two different spots. The fluid is reddish in color, very thick/oily and does not evaporate. Quickly inspected engine compartment and undercarriage and found a drop of the fluid on the underside panel but was not able to find the origin. Will have to take underside panel off to get a better look.
Old Nov 21, 2006 | 06:17 AM
Scenic Driver's Avatar
Is it an automatic?
Old Nov 21, 2006 | 06:20 AM
EzAudi's Avatar
New Member
5 spd 180 non-quattro 96k miles
Old Nov 21, 2006 | 06:26 AM
rumburak's Avatar
Default Shot int the dark....G12 coolant? >>
isn't the transmisson more to the driverside.
Take the Belly Pan off and look around the Turbo coolant hose, that is common leak for the G12 coolant.
Old Nov 21, 2006 | 06:27 AM
Are you sure it's not coolant. I believe that is the only red fluid.
Old Nov 21, 2006 | 06:31 AM
EzAudi's Avatar
New Member
Seems too thick and oily to be coolant. What color is manual tranny fluid?
Old Nov 21, 2006 | 06:37 AM
Default It's been a while since I changed the factory oil >>>
But I believe it was honey colored like motor oil (if I am wrong someone please correct me here).
Your going to have to get under there, take the belly pan off, and take a look.
Also, manual tranny fluid is called gear oil.
Old Nov 21, 2006 | 06:38 AM
dougie's Avatar
25 Year Member
G12 is more thin and pink
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 21, 2006 | 06:49 AM
EzAudi's Avatar
New Member
Default I guess I'll resume driving it since nobody has chimed in saying something has grenaded....
Been driving my Beast of a Landcruiser for the past few days and have missed the little guy.
Gear oil - oops, guess that's why I majored in electronics.
Old Nov 21, 2006 | 06:58 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default Manual tranny oil at around 30K...
<img src="http://images9.fotki.com/v199/photos/4/435091/2385138/03Smellyfluiddrain-vi.jpg">
<img src="http://images12.fotki.com/v196/photos/4/435091/2385138/04Oldfluid-vi.jpg"><ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/engine_and_drivetrain/transmission_oil/">http://public.fotki.com/mcphill/audi_stuff/engine_and_drivetrain/transmission_oil/</a</li></ul>
