another oil change question...
Old Nov 21, 2006 | 06:46 PM
EmoryDPTT's Avatar
Default another oil change question...
hey guys, i'm going to be changing my oil soon and have been searching the posts and see that it seems like a pain to do. my B5 A4 quattro was a piece of cake, but what about the TT?mine's a non-quattro 2000 coupe and was wondering what you guys would caution or any words of advice. i've only had the TT for a month now and its about to reack 40K miles. Will be using Mobil 1 0W-40 and purchased a Mahle(Mann) OEM filter. How much oil? 4.5 quarts? Also
will be changing spark plugs. am i missing anything? thanks in advanced guys.
Old Nov 21, 2006 | 07:21 PM
jhoeppel's Avatar
Default yep on the 0w40, the Mann oil filter, and I think 4.5 qts sounds about right.
Buy a six-pack of the Mobil1 0w40 and keep the extra 1.5 qts for topping up over the next 10k miles. Most of my engines use Mobil1 quicker than other synthetics (like Valvoline or Castrol) but a Mercedes-Benz engineering study a few years back on extended oil drain intervals seemed to indicate that topping up was actually helpful as it replenished the additive packages, making oil drain intervals as long as 15-20k miles Ok. YMMV.
Tip#2: slip a zip-lock bag around the spent oil filter as soon as you get it unscrewed. It makes it a bit cleaner to fish it out. Some people punch a hole in the bottom of the old one to drain it once it's loosened.
Tip#3: loosen the clamps holding some of the flexible lines that attach to that horizontal tube; it'll make it easier to move that tubing aside when fishing the old oil filter out.
Good luck and just have patience... it's not as difficult as changing the air filter on an '01 Passat<i>!</i>
element2050's Avatar
New Member
Default DIY LINK
http://blackforestmotorsport.com/mikep/ttoilchange.htm
i use about 4.7q 5-30w I use synthetics I like Valvoline... Mobile 1 burns easy so u have to top off between changes.
spark plugs are cake work i think u TQ them at 20lb
Old Nov 21, 2006 | 07:25 PM
jhoeppel's Avatar
true on Mobil1 burning off but thay may not be so bad (see my reply immed below)
Old Nov 21, 2006 | 09:06 PM
BRC's Avatar
BRC
Junior Member
actually it's 22 lbs.
Old Nov 21, 2006 | 09:08 PM
SparTTan's Avatar
Default Spread out newspapers or cardboard and keep a roll of paper towel handy... It's a messy job.
Oil capacity is 4.8 quarts.
Old Nov 21, 2006 | 09:10 PM
SparTTan's Avatar
Default I've used Mobil 1 since I started doing my own oil changes and have never added any between changes.
Oil level has never dropped. I use 5w30 weight.
Old Nov 21, 2006 | 09:16 PM
BRC's Avatar
BRC
Junior Member
2nd. change every 7-8k miles and have never needed to add between changes
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 22, 2006 | 05:59 AM
JustJeff's Avatar
Default another plug change answer...
Follow this link to 'coli pak' change.
You need to remove these anyway to get at the plugs.<ul><li><a href="http://www.loomknitting.com/auditt/coilpak.html">Plug/Coil Pak change</a></li></ul>
Old Nov 22, 2006 | 08:19 AM
EmoryDPTT's Avatar
Default Re: another plug change answer...
Yea, that's very similar to my SR motor but this just seems a little bit more of a pain in the *** to get the coilpacks out to access the plugs.
