Need some help... I am installing a mechanical boost gauge and
Old Nov 22, 2006 | 08:37 AM
TTontheREAR's Avatar
New Member
Default Need some help... I am installing a mechanical boost gauge and
I just want to make sure I am doing it correctly. I am new to the modding and I just hooked uo a stewart warner boost gauge. I hooked the hose with a tee from the diverter valve to the gauge. Before putting it all back together, I started the car and got nothing. Should I be seeing vaccum? Did I hook the hose up correctly? Any help would be greatly appreciated.
Thanks In Advance
Old Nov 22, 2006 | 08:41 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Not sure the DV is a good source. Many use the vacuum line to the Fuel Pressure Regulator.
Old Nov 22, 2006 | 08:42 AM
whodkne's Avatar
Member
I'll let you know this weekend
Lowcountry's Avatar
Default I put my T on the vac line leading to the fuel pressure regulator.
It works like a champ from there.
New Member
Do you happen to have a picture of where that is located?
Old Nov 22, 2006 | 08:45 AM
graviTT's Avatar
Junior Member
2nd
Old Nov 22, 2006 | 08:46 AM
Scenic Driver's Avatar
DV gets vacuum from n279 valve, not a good source. Use the fuel pressure regulator vacuum line.
Old Nov 22, 2006 | 08:47 AM
Lowcountry's Avatar
I just did a quick ("boost gauge" fpr ) search for only links w/photos and got lots of pics of it...
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 22, 2006 | 08:49 AM
Tech Guru
Default Do I have a picture?! ; )
<img src="http://images18.fotki.com/v231/photos/4/435091/2750321/059Enginecoveroff-vi.jpg">
Gage line is the "greenish-black" one to the right of the FPR (lower right of valve cover), headed straight back to the firewall. Used a triple "Y" style connector to splice in (part of the AWE kit).
Yep, I did one for "fuel pressure regulator", 3rd result has a picture.
