Some codes, my codes file apparently wont load, can someone identify & help!
but these codes: im stuck in limp (5psi) after installing wayne's o2 sensor block. all it is, is an L shapped piece that seperates the secondary o2 sensor from the car.
I ran vagcom before & after. Codes are below..
as well as i checked block 118 & 115 and my cmd pressure was 1000mbar and my press @ intercooler was 130mbar. thats a big leak it sounds like. so i checked all hoses. ran a pressure test. no results.
any help please!!
BEFORE NEW O2 HOLDER:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8N0 906 018 T
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 06610
Work Shop Code: WSC 01236
3 Faults Found:
16806 - Can't Decode, CODE File Not Loaded!
P0422 - 35-00 - Can't Decode, CODE File Not Loaded!
17743 - Can't Decode, CODE File Not Loaded!
P1335 - 35-10 - Can't Decode, CODE File Not Loaded! - Intermittent
16621 - Can't Decode, CODE File Not Loaded!
P0237 - 35-00 - Can't Decode, CODE File Not Loaded!
AFTER NEW O2 HOLDER: went for a short ride, heard a popping sound from front left of car with windows open. Car hesitated. Took it home. Read these.
2 Faults Found:
16490 - Can't Decode, CODE File Not Loaded!
P0106 - 35-00 - Can't Decode, CODE File Not Loaded!
I have a CEL because I don't have cats.
Here's a picture of the spacer which I'm sure there may be some interest in with the upcoming release of the 42DD downpipe/testpipe.
<img src="http://www.42draftdesigns.com/images/cnc/wayne92slc.jpg">
Trent
