Manifold pressure issue:
Old Nov 22, 2006 | 08:21 PM
VorsprungTT's Avatar
Default Manifold pressure issue:
16621 - Manifold Pressure / Boost Sensor (G31): Signal too Low
P0237 - 35-00 - -
Is the code I am recieving.
With the key in position 2, car off, I can clear the code and it will pop up again in a second.
What are my options here?
Old Nov 22, 2006 | 08:34 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
MAP sensor? It's under the battery (on a 225).
Old Nov 22, 2006 | 08:38 PM
Tech Guru
Default These shots should help you locate it...
MAP pipe is bottom right of this screen
<img src="http://images18.fotki.com/v331/photos/4/435091/3820107/DSCN7636-vi.jpg">
I think the MAP sensor is visible here (bottom right):
<img src="http://images18.fotki.com/v328/photos/4/435091/3820107/DSCN7637-vi.jpg">
Old Nov 22, 2006 | 09:43 PM
Default I have access to it. I don't have a battery there, its in the trunk. I cannot get one of the screws.
out, the one further into the engine bay seems to be stuck.
As well as, when i get it out what should i do with it? clean it? buy a new one?
Old Nov 23, 2006 | 07:40 AM
sTTevo's Avatar
Default Since you now have the room, you should fab up a new pipe WITHOUT the pancake treatment.
42DraftDesigns sells a MAP sensor mount. Maybe a muffler shop could bend some pipe to match OEM pancake pipe and weld on the mount. I would think that a round cross section pipe would flow air much better than the squished stock one.<ul><li><a href="http://www.42draftdesigns.com/18tmapsensors.htm">MAP sensor mount</a></li></ul>
Old Nov 23, 2006 | 08:54 AM
Tech Guru
Default You mean like this? (Tell Steve to get off the pot!)
<center><img src="http://images15.fotki.com/v233/photos/4/435091/2891071/DSCN5213-vi.jpg"></center><p>
Old Nov 23, 2006 | 10:53 AM
Happy thanksgiving! where can i grab a new map sensor. this problem is pissing me off.
Old Nov 23, 2006 | 10:59 AM
Tech Guru
Default Don't know. Dealer would be a quick choice, but worldimpex, 1stvwparts, etc. will likely be
cheaper. I don't have a part number either.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 23, 2006 | 01:36 PM
sTTevo's Avatar
Default Happy Thanksgiving all. Just back from a spin with top down. Found this on World Impex:
I am not 100% certain this is the part, but it looks like a manifold air pressure (MAP) sensor to me......<ul><li><a href="http://www.worldimpex.com/item_detail.html?sku=176667">MAP sensor?</a></li></ul>
Old Nov 23, 2006 | 02:36 PM
Default Thanks, I'm going to take the pipe off today and check for cracks/leaks & the sensor...
I wonder if there is anyway to fix it. I don't need my car for the next few days since I can't go anywhere. I have a minior heart condition that has to be taken care of early next week.
If I cannot fix the sensor in anyway or the connections arent messed up on the harness, I'm going to order a new one and the 42DD sensor holder. Has anyone fabbed their own pipe up before?
