So I have my KW 8012 springs in the rear, and I STILL have one perch all
Old Nov 23, 2006 | 09:45 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default So I have my KW 8012 springs in the rear, and I STILL have one perch all
the way down (the other about 1/4" up)... I wouldn't mind going little lower, but I need adjustment to keep it corner balanced. Guess my only option is to cut the springs, or find some that are lower from another manufacturer? Certainly lower than the original springs, but not as low as I was hoping they would be...
Old Nov 23, 2006 | 10:49 AM
Russ Scott's Avatar
Default remove or flip the adjusters, use shims to get the 1/4...
cut springs rarely work well. Tried it... it seems to increase the spring rate disproportionately. You get "bounce".
Old Nov 23, 2006 | 02:20 PM
SporTTy's Avatar
Junior Member
Default my V3's came with the 8012 springs, KMD flipped the rear perches and left out the height adjuster
<center><img src="http://pictureposter.audiworld.com/107981/dropped7_500.jpg"></center><p>I dont have height adjustment in the rear anymore and only have height adjustment up front but I am as low as I can go in the rear with the 8012 springs with 18" wheels. If I ever run 19's, then I may end up putting the rear height adjusters back on.
Old Nov 26, 2006 | 07:23 PM
kodeTT's Avatar
Elder Member
Default did you remove the white spacer on the bottom of the rear springs?
that will give you another 3/8" lower i believe.
Old Nov 26, 2006 | 07:24 PM
kodeTT's Avatar
Elder Member
also, take out the 1.5mm silver washer out.
Old Nov 26, 2006 | 07:40 PM
Tech Guru
No... For the life of me, I could not get the rubber piece on top of it out. Got a tip to do that?
Old Nov 27, 2006 | 05:11 AM
kodeTT's Avatar
Elder Member
Default the rubber has a blunt pin on it...and attached to the white spacer. there's a large metal
piece under the rubber as well. most likely...like with mine, it has rusted into place.
what i did was to use a small crowbar and gently lift up all the edges upward until it gave way. it was rusted on the center bump stop with the inner ring...if that helps. it was hard to understand how it was placed in until i removed one of them (the easier of the two)...once i saw how it was put in, the other was easy to get out.
so the rubber pin goes through the bottom spring platform...so it won't rotate...which is why you won't be able to rotate it free until you get the rubber pin out of the slot.
Old Nov 27, 2006 | 06:33 AM
Tech Guru
Default Guess I'll give it another go if/when I get my new shocks... Gotta keep ride height here now,
for a while, though, with the new alignment and all...
 Pouria Savadkouei
 Michael S. Palmer
islingtonaudi
Audi 100 / A6 (C4 Platform)
Dec 31, 2008 01:17 PM
MSP_S4
Jan 19, 2006 04:49 PM
Rich L.
Audi Original "S" Cars
Sep 25, 2003 06:04 PM
wisconsin_quat
15
Sep 5, 2003 05:31 AM
Davidos2
Jan 24, 2002 11:29 AM
