Any hack directions available for changing lighter outlet power with key on...
TIA
Jack
All you would need to do is to find the wire at the connector on the back of the ash tray, cut it, not the brown one, near the connector, splice a wire to it at that point, and run it back to the fuse box.
you'll need to drop the lowerdash, and remove the side panel, drivers side of the console under the radio/HVAC unit.
You can then get at the connector to the cig. lighter there, probably with out even removing the ash tray.
I'd say it's a 20 min. job, tops.
Easy.
<img src="http://www.loomknitting.com/auditt/images/ashtray.jpg">
<img src="http://www.loomknitting.com/auditt/images/ashtray4.jpg">
Jack
