Got all these codes basically at once. Has this happened to anyone?
P1137 - 35-10 - - - Intermittent
16826 - EVAP Emission Control Sys: Small Leak
P0442 - 35-10 - - - Intermittent
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-10 - - - Intermittent
17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting
P1564 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent
What I mean by "all at once" is that i just vag the car a couple a days ago and there was no codes. The cars idle was running higher and it wasnt very smooth, and it only boosted to 8 psi. I cleared the codes and now everything seems fine. Any ideas what happened?
tia
I was told could be a vac leak but then my CEL went off and seems to be running fine again once the car warms up...
Engine doesnt sound perfect but back to how it was before.. Still a smallllll clicking noise while idling (but it always did that if i remember correctly) How do i fix this?
