Anyone ruin the rear bushings on the Defcon install?
Old Feb 10, 2007 | 10:21 AM
M power this!'s Avatar
Default Anyone ruin the rear bushings on the Defcon install?
i'm a pretty good mechanic but not all that experienced w/ a press. anyway, my dealer did not have the exact diameter fitting to press in the rear bushings. it went in only a hair crooked. so i just pressed down the edge that was high and presto...........NOT. ****ing bushing can now be pushed in and out by hand now. negatives of soft aluminum. SO i was much more careful with the second one and Mike, sorry I needed to steal one of Peters to finish my car. I'll have to buy another one. fronts were easy.
Old Feb 10, 2007 | 10:37 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default Well, at least you had Peter's handy! For pressing items in, you don't need anything
close at all - you just need a large plate with a hole in it (to clear the center metal that sticks up higher). Heck, a 1'x1' plate (with a hole in it) would work fine!
Old Feb 10, 2007 | 10:42 AM
Default If you can believe it, our WHOLE damn dealer has no plate with a big enough hole!
had to use the old bushings sleeve. also that POPPING noise has the Defs go in is scary!
Old Feb 10, 2007 | 10:48 AM
Tech Guru
Default You should've come by wih Garry ; )
Did you use some anti-sieze on the DEFCONs? If don't think they sound nearly as bad going in as the OEM bushes do going out - THAT I fine scary!
Are you aligned? How's it drivin?
Old Feb 10, 2007 | 11:39 AM
At work, still waiting for my step dad to bring the other box. Arms are here, car home
Old Feb 10, 2007 | 11:40 AM
Oh yeah, what were the 3 different torque #'s?
Old Feb 10, 2007 | 12:44 PM
Tech Guru
Default Torque specs...
Torque specs for reinstallation of front lower control arms after installation of DEFCON parts in to the arms (how's that for a nice keyword search list?!)
Control Arm Bolts: 50 ft-lb (70 Nm) PLUS a quarter turn (90 degrees).
Ball Joint Nuts: 55 ft-lb (75 Nm)
Old Feb 10, 2007 | 06:41 PM
Thank you! Got everything set.
 Pouria Savadkouei
 Michael S. Palmer
Redd
Q5/SQ5 MKI (8R) Discussion
11
Jun 4, 2019 05:40 AM
jk06a8
Q7 MK 1 Discussion
Mar 21, 2014 09:31 AM
S4lorn
12
Aug 19, 2007 06:11 PM
dscottjr
Jun 1, 2006 04:51 AM
white90+hibredS4
May 8, 2005 05:20 PM
