2 things....New plugs and code
Old Feb 11, 2007 | 02:04 PM
kaiwooglin's Avatar
Default 2 things....New plugs and code
Just put in NGK Iridium ix plugs, I let it idle for about 3 or 4 minutes and now it seems to be sputtering. Any ideas?
Also vaged yesterday came up with same code before.
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
See others have this code and posts about it, but havent seen anything about a fix. O2 and MAF replacement??
Old Feb 11, 2007 | 02:05 PM
XCLR8TT's Avatar
Senior Member
Unplug the MAF and see if the problem goes away. The ECU will use the default maps.
Old Feb 11, 2007 | 02:07 PM
BTTI's Avatar
Senior Member
Are they gapped correctly?
Old Feb 11, 2007 | 02:11 PM
kaiwooglin's Avatar
I have no clue, just got the box and popped them in, doesnt say anywhere on box about gap size
Old Feb 11, 2007 | 02:15 PM
BTTI's Avatar
Senior Member
Default That could be the issues right there. >>
I'd take them out and gap them. Then throw them back in and see what happens. As far as the gap specs - search around on here and see what they should be gapped to.
Old Feb 11, 2007 | 02:20 PM
XCLR8TT's Avatar
Senior Member
0.32 stock gap
Old Feb 11, 2007 | 02:24 PM
kaiwooglin's Avatar
Default well the gap one the ones i put in did look narrower than the ones i pulled out.....
but ok now im stupid where is the MAF to unplug
Old Feb 11, 2007 | 02:31 PM
XCLR8TT's Avatar
Senior Member
Default The older one's gap probably opened over time from the electrode burning off.
The MAF is the sensor plugged into the black tube just downstream from the air filter.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 11, 2007 | 02:34 PM
kaiwooglin's Avatar
Can I drive with the MAF unplugged?
Old Feb 11, 2007 | 02:45 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
yes
