Silicone Turbo Hoses
Old Feb 11, 2007 | 03:30 PM
HRG3's Avatar
Default Silicone Turbo Hoses
Gang:
I've been trolling around extensively through the various TT groups from here to the UK etc trying to clear up something. If I do a stage one Revo remap should I be looking into the upgraded hoses also? There seems to be a thread that says the intake side will collapse under hard excelleration. Also there seems to be some who say that the newer TTs don't do this. Mine is a 2002 225, what is this group's thinking on this? Is this real, or do the hoses just look really cool?
Thank you:
Rick Glesner
Littleton, Colorado
Old Feb 11, 2007 | 03:41 PM
blackfnTTruck's Avatar
Default I have Revo with an '03 and have no problems, I think you are correct that it.....
was a problem on older TTs, not sure when it changed.
Old Feb 11, 2007 | 03:48 PM
Default Here is an old thread worth looking through, with a video of the hose collapsing...
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1585913.phtml">Click</a></li></ul>
Old Feb 11, 2007 | 04:51 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default You don't need the hose (problem on '00 and some early '01s). You can still do the hose, though
and it may provide a very minimal increase in flow, as well as (very) slightly more heat insulation to the incoming charge air.
Old Feb 11, 2007 | 07:54 PM
M power this!'s Avatar
Correct, basically a waste of money. the newer hoses do NOT impede flow/power
Old Feb 11, 2007 | 08:58 PM
Tech Guru
Default I wouldn't call it a waste of money - it still looks nice!
Just no a high priority "performance" mod.
Old Feb 12, 2007 | 03:44 AM
Forge's Avatar
Junior Member
Default Some gains to be had apparently
<ul><li><a href="http://www.forgemotorsport.co.uk/tt_hose.html">Tip hose Forge not Samco ;-)</a></li></ul>
Old Feb 12, 2007 | 06:24 AM
MaD MaTTer's Avatar
Default could anyone verify the part# for the '01 intake hose with a tendency to collapse...
i have a mid '01 225 and I took these two part numbers of the intake hose.
one # was part of the mold of the hose and another number was printed on white ink.
these are the two part #'s on my intake hose
molded rubber: 06A 133 356 F
printed in white: 06A 145 892 AR
I wanted to know which Rev of the hose i have.
 Pouria Savadkouei
 Michael S. Palmer
703AudiTT
May 21, 2008 08:40 AM
aviator180hp
Dec 24, 2006 04:05 AM
Mr. Nice Guy
Mar 8, 2005 08:28 AM
the Quiet sTTorm...
Aug 7, 2003 12:48 AM
Natedawg
10
Apr 22, 2003 11:55 AM
