advice needed on upcoming suspension upgrade...
Old Feb 12, 2007 | 10:26 AM
difficulTT's Avatar
New Member
Default advice needed on upcoming suspension upgrade...
at 82k I think its finally time to replace the stock suspension. I am planning on using the Bilstein HD's, as well as a larger rear swaybar (Neuspeed or H&R). What else should I change while I'm there? I was going to order ECS's Complete Upper Strut Mounting Kit With Upper Spring Perches (2 Upper strut bearings, 2 Upper strut mounts, 2 Upper spring perches, 2 Upper securing nuts)...Is there anything else I need/should replace?? Anyone have an opinion on the Neuspeed vs. H&R swaybar?? Any other suggestions??
Thanks for taking the time
Geoff
Old Feb 12, 2007 | 10:31 AM
PracTTical's Avatar
sway bushings if not included with kit?
Old Feb 12, 2007 | 10:34 AM
difficulTT's Avatar
New Member
noted...thanks!
roadyTT's Avatar
Might as well do the front swaybar while you're in there
Old Feb 12, 2007 | 10:43 AM
XCLR8TT's Avatar
Senior Member
DEFCON
ttrut's Avatar
Member
And if you don't, at least put on some poly bushings so you don't get the squeak.
Old Feb 12, 2007 | 10:48 AM
difficulTT's Avatar
New Member
That is part of the plan eventually...@#$% budgets
Old Feb 12, 2007 | 12:20 PM
XCLR8TT's Avatar
Senior Member
Default It would be cheaper to put them in now rather than later. I'd have done it, but Mike's announcement
came out 2 weeks after I'd just dropped $600 for an alignment and corner balance.
 Pouria Savadkouei
 Michael S. Palmer
VONBOTTLE
24
Apr 10, 2011 09:50 PM
TTALMS
Oct 17, 2008 03:36 PM
TTempted
13
Mar 15, 2007 03:58 PM
Basttion
14
Jan 29, 2007 07:16 PM
owdeeS4
9
Apr 19, 2002 10:46 AM
