Is it possible to run a relatively thick (1/8") cable through this vent?
The one circled in red:
<img src="http://www.contrib.andrew.cmu.edu/~ttrutna/images/fusebox.jpg">
I'm getting ready to do a Garmin Nuvi hardwire install, but I want to mount it next to the A pillar rather than above the center console as Stilljester and others have done.
P.S. Thanks to Jeff for this image and his awesome website for a very simple hardwire solutions.
I had my boost gauge tubing and wiring running through that vent hole.
they also mounted it in the ash tray, it could even close!
they ran the aux antenna up to the center vent, completly seamless install.
so seamless here's the link<ul><li><a href="http://forums.vwvortex.com/zerothread?id=3003822">Garmin Nuvi seamless installation
</a></li></ul>
Your website really is a wealth of information and has inspired me to clean up some wires in my TT.
You can push it away from the A pillar and get cables from the lower dash / fuse carrier to the left hand corner.
I was able to get both a mini usb connector and a 12 volt passport connector from the fuse box to the devices this way
