Exhaust leak found!
Old Feb 13, 2007 | 01:26 PM
Lowcountry's Avatar
Default Exhaust leak found!
Well, I finally got the time today to track down my annoying exhaust leak. I was concerned that I might have a cracked exhaust manifold (THANKS HANS!!! :-( ). As it turns out, the manifold is not cracked. I have lost a nut from one of the 3 flange bolts between the curved part of the DP and the flex joint. That sucker vibrated right off. Should be a real easy fix (remove charge pipe, maybe strut brace, add new nut, tighten). The bad news is that it's a 13mm nut, and the only store I had time to check with today didn't have 13mm nuts. They had 12mm and 14mm, but no 13mm! WTH? Hopefully I can track some down tomorrow at another location. Anyhoo, the problem isn't nearly as bad as I was fearing.
PS. To those of you with 42DD dp's, check your nuts!
Old Feb 13, 2007 | 02:29 PM
roadyTT's Avatar
My nuts are ok.....<whew!>
Old Feb 13, 2007 | 03:14 PM
TTinCT's Avatar
Rest In Peace
Default LOL...well i am glad it was only a nut>>>
but you know why i said that! ;-)
Glad to hear it is resolve Charles...well..almost!
Old Feb 13, 2007 | 03:53 PM
42TT's Avatar
Former Vendor
Default You need a 5/16"-18 x 1 1/4" fully threaded grade 2 bolt, lockwasher, and nut>>
I'm American, I use American hardware
You need a fully threaded bolt. The bolt screws in through the flex pipe joint and then into the top most portion of the DP. Like a stud, so that you can access the nuts on this flange.
Evan
Old Feb 13, 2007 | 04:41 PM
Lowcountry's Avatar
Evan, the bolt is still in place, actually. I just need a nut and a lockwasher to go on it.
Old Feb 13, 2007 | 06:59 PM
sTTevo's Avatar
Is 42DD DP still clearing brackets, etc. on your roadster? Hope to do this mod someday.
Old Feb 13, 2007 | 07:03 PM
NOLA TT's Avatar
Default Check your nuts...
<center><img src="http://pictureposter.audiworld.com/113335/das_klote.jpg"></center><p>
Old Feb 13, 2007 | 07:47 PM
42TT's Avatar
Former Vendor
Sweet, than grab a 5/16" nut and lockwasher from Home Depot and call it a day
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 14, 2007 | 01:20 AM
snowpunk_AGTT's Avatar
those nuts are bigger then her cans!!! eewwww.
Old Feb 14, 2007 | 08:14 AM
Lowcountry's Avatar
Default Yup, nary a clunk, even at full throttle from a dead stop.
Of course I did have to replace the OEM dogbone bushing with a firmer polyurethane one, but hey, what matter $12.00? The pipe is a pleasure on multiple levels.
