Any obvious reasons why an engine won't turn over? >
Old Feb 14, 2007 | 12:56 PM
cdaniels's Avatar
New Member
Default Any obvious reasons why an engine won't turn over? >
Today for the first time, and quite unexpected, my engine wouldn't turn over. Battery was fine, starter was firing.. but the engine just wouldn't turn. I backed it out of the parking space while trying to pop the clutch and push start it but nothing. Tried the key again it fired up just fine.
Any obvious reasons for this or will I have to chase a gremlin?
Old Feb 14, 2007 | 12:59 PM
XCLR8TT's Avatar
Senior Member
VAG-COM it first to see if there are any codes.
Old Feb 14, 2007 | 01:00 PM
KSpider's Avatar
No gas? That would be the most obvious reason I can offer you...
Old Feb 14, 2007 | 01:06 PM
oldseTTer-WWKD's Avatar
Default Define "wouldnt turn over"
did the engine spin but not fire?
did the starter whir but not spin the engine?
did the starter soloniod engage but not spin?
Old Feb 14, 2007 | 01:07 PM
SilvrBulleTT's Avatar
Default yup
check your coolant temperature sensor. you probably need a new one (green color). it's like 6 bucks from the stealer. i had the same exact problem and that fixed it.
Old Feb 14, 2007 | 01:12 PM
Scenic Driver's Avatar
They haven't been $6 for a while, now they are more like $25
Old Feb 14, 2007 | 01:16 PM
cdaniels's Avatar
New Member
I could hear the starter whir.. but no engine fire.
Old Feb 14, 2007 | 01:18 PM
BlueChip's Avatar
Default If it's not the temp sensor check the ......
battery connections/cables. Sometimes the battery contacts get dirty/corroded and enough juice gets by to fire up the starter but not enough to turn the engine.
BC
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 14, 2007 | 01:50 PM
Trey (at pitt)'s Avatar
Default Does it sound like this?
<ul><li><a href="http://www.scelusweb.com/wontstart.3g2">Failed fuel pump</a></li></ul>
Old Feb 14, 2007 | 01:53 PM
cdaniels's Avatar
New Member
Thanks a ton! I'm SO glad I have a place to ask these kinds of questions!!!!
