MAF screws? Any tips on removing them?
Old Feb 16, 2007 | 07:30 AM
BTTI's Avatar
Senior Member
Default MAF screws? Any tips on removing them?
I know, I know...dynamite.
Those tamper-proof screws are a PITA! Last time I used pliers to loosen them. This time...it doesn't work. How do I remove them? Is there a tool that I could get?
Old Feb 16, 2007 | 07:35 AM
javedikian's Avatar
Default Re: MAF screws? Any tips on removing them?
I bought the adapter at autozone for a couple dollars. Don't know the size but they let me go out to the parking lot to check.
nightdweller's Avatar
New Member
Default ACE hardware sometimes has a screwdriver kit with the proper bits. If not>>
Hit EBAY or search google for security torx bits. I think i've seen them at harbor freight too. I've got a set but I'm assuming your not close to central Ohio.
Old Feb 16, 2007 | 07:36 AM
adminisTerTurbo's Avatar
Default dremel some slots in them for a flat head
go slow, they get hot. don't want to melt the housing.
Old Feb 16, 2007 | 07:37 AM
BTTI's Avatar
Senior Member
Default Thanks for the offer...little far to drive though :)
Although, I may be in Cleveland soon. I'll see what I find through ACE first.
Old Feb 16, 2007 | 07:41 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Next time...>
Replace those suckers with regular #8 Phillips head screws!(or better yet, buy a ****!) Your car should be ealrly enough that a regular security Torx bit should work. Newer ones use a more secure Torx for which Bits are not available....
Old Feb 16, 2007 | 07:45 AM
BTTI's Avatar
Senior Member
Default That would be perfect. I'll give that a shot.
The MAF isn't in the car yet, so I'll just bring it in. Thanks!
Old Feb 16, 2007 | 07:48 AM
BTTI's Avatar
Senior Member
Default "Next time" already happened...
I have the setup from you. I have a new MAF that I need to remove from the housing itself. Damn those security torx bits! It's a 5-star bit with the hole in the middle. I have 6-star bits with the hole...no good.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 16, 2007 | 07:49 AM
BTTI's Avatar
Senior Member
That's a good thought too. Thanks!
Old Feb 16, 2007 | 07:58 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default Vise grips usually do it for me. Never put those screws back in. The Dremel slot idea
is a good one too.
