Fuel gauge showed 0 / flat when I know I had a half tank of fuel
Old May 14, 2007 | 09:51 AM
imager993's Avatar
Default Fuel gauge showed 0 / flat when I know I had a half tank of fuel
I was at the track this weekend and when I was driving from my spot to the grid, I noticed that my fuel gauge was showing below empty; it looked like it had no input. I got out and wiggled the wires in the back where the spare tire goes (removed for the track) and nothing changed.
I knew that I still had a half tank left so I figured I would go out on the track anyways. A few minutes later, I glanced down to see how it was doing, and it was back to normal.
Is this signs of a cluster going out or more likely just a bad connection from the fuel sensor? I do not think the cluster has ever been replaced on this car.
Tnx
Old May 14, 2007 | 10:10 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Probably fuel senders...Try the Techron Fix...>
Run a few bottles of Techron through over the next few tankfuls....Usually scrubs the sender contacts clean and things will return to normal..
Old May 14, 2007 | 10:25 AM
imager993's Avatar
Does it help in the long run that I always use Chevron fuel that has Techron in it?
Old May 14, 2007 | 10:27 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Do a concentrated Mix with the additive...>
It fixed mine, and quite a few others here..
Old May 14, 2007 | 10:42 AM
imager993's Avatar
Default Thanks, I'll definitely run the concentrate to fix this problem, but...
I am wondering if running Chevron fuel that has the low concentration of Techron will help the long term life of the fuel system?
Old May 14, 2007 | 12:21 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Sure!
Old May 14, 2007 | 01:12 PM
imager993's Avatar
Thanks Steve
mart_o_rama
Dec 19, 2024 06:16 PM
OCDboy
Feb 10, 2006 02:22 PM
Whitjr
Jan 26, 2005 05:42 PM
donp@audiworld.com
Aug 16, 2000 07:04 AM
