Spec Clutch 2+ guys (marTT).....did they send me the wrong clutch?
Old May 14, 2007 | 03:01 PM
iTTaliano's Avatar
New Member
Default Spec Clutch 2+ guys (marTT).....did they send me the wrong clutch?
<center><img src="http://pictureposter.audiworld.com/95672/spec_a.jpg"></center><p>I was comparing to marTT stage 2+ pictures and mine is definitely different. There are none of the 5 small springs (don't know the name of them)on the clutch disk as on marTT's pics or on the SPEC website pics....what gives??
Old May 14, 2007 | 06:18 PM
MarTT's Avatar
Default Maybe they sent me the wrong clutch!! Please call them tomorrow and show them
these two images . . . your Stage 2+ clutch disc:
My Stage 2+ clutch disc (sitting atop flywheel):
<img src="http://images112.fotki.com/v588/photos/4/41970/4873107/DSCN5461-vi.jpg">
Russ Scott's Avatar
Default a lightened flywheel requires the springs in the disk, the OEM dual mass
flywheel does not... as a general rule.
Old May 14, 2007 | 06:19 PM
MarTT's Avatar
Hmm, I did not order the alum flywheel, but the Spec steel is a little lighter than stock.
Old May 14, 2007 | 06:26 PM
Russ Scott's Avatar
Default Sorry, I don't know the specifics for Spec. A South Bend Stg III
was installed in my car recently with the OEM flywheel... no springs in my case. I'll second your suggestion though, a call to Spec could save a lot of trouble...
Old May 14, 2007 | 06:36 PM
iTTaliano's Avatar
New Member
Default Thank you, that make sence >>
When I placed the order online, they gave me a call to verify what flywheel I was using. I am using a stock flywheel....soo no springs in the disk it is :-)
Old May 14, 2007 | 06:40 PM
iTTaliano's Avatar
New Member
marTT, did you specify what flywheel u were using when u ordered your clutch?
Old May 14, 2007 | 06:42 PM
iTTaliano's Avatar
New Member
OK, I'll call Spec in the a.m and I'll send them both pics.....
 Pouria Savadkouei
 Michael S. Palmer
Old May 15, 2007 | 02:11 AM
MarTT's Avatar
I ordered the entire kit from SPEC. So I have their flywheel (steel).
Old May 15, 2007 | 02:12 AM
MarTT's Avatar
Post here with your findings, inquiring minds want to know. ;-)
