Turn signals won't fire. . .question...
Old May 14, 2007 | 09:19 PM
Vocalize's Avatar
New Member
Default Turn signals won't fire. . .question...
2001 TTQuatro Coup.. Turn signals - both sides - initiate and then stop. They won't stay 'fired.' `Sound like thermal flasher needs replacing? I looked up the fuse array in the manual, but there's no mention of the thermal flasher.
I'm not very 'hands-on' but hate to do the repair trip thing. Is this something I should try to replace? And. .um. . .where is it?
Thanks..dm
Old May 14, 2007 | 09:32 PM
Jdog35's Avatar
Junior Member
Default Just use a flare gun. Shoot one out the right window when going right. Out the left when going left.
Problem solved.
Old May 14, 2007 | 10:19 PM
andrew.tt's Avatar
Default do a search on blinker relay or hazard relay >>
i just replaced mine because sometimes they would just stay "on" and not blink.
Old May 14, 2007 | 11:47 PM
Vocalize's Avatar
New Member
Default Re: do a search on blinker relay or hazard relay >>
Thanks for the advice. . another dandy little fairly common wrinkle. Doesn't sound like anything *I* can handle, though. Off to the repair shop again. . . sigh. . . at least I know to call it a 'blinker relay.'
Old May 15, 2007 | 04:51 AM
BTTI's Avatar
Senior Member
LOL Sounds like one of my solutions
Old May 15, 2007 | 08:17 AM
Vocalize's Avatar
New Member
Since once initiated the hazards function properly, it's probably the switch on the steering column?
Guess this means a repair appointment. Argh.
Thanks.
dm
Old May 15, 2007 | 10:41 AM
Vocalize's Avatar
New Member
Default Re: Turn signals won't fire. . .epilogue...
Got in touch with my service guys. No sooner than I said the words 'turn signals. .' than he said 'know exactly what it is. Two hours and $300!" It's an inexpensive blinker relay, but it's behind the radio - labor costs, etc.
I've had enough go wrong over six years to *almost* regret the purchase.
dm
Old May 15, 2007 | 01:05 PM
jhoeppel's Avatar
Default $300? <head explodes> It's actually not hard or complicated.
might take 15-30 mins tops if it's the first time you do it--a link from earlier today says 5 mins (see link below).
Pulling the radio requires a special tool (but you can make them from pendaflex folders for free). Search on hazard relay. I think Jeff has a DIY with pictures. If not him, then others do. Keep your $300.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1642284.phtml">see this link from earlier today</a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
blue3.2A4
A4 (B7 Platform) Discussion
Jan 8, 2011 08:29 AM
ludachrisA6
Jul 24, 2009 12:31 PM
galore
Nov 28, 2007 04:50 PM
Killer Bee
Feb 5, 2004 08:35 AM
