Voltage question..
Old May 15, 2007 | 10:23 AM
TTuned's Avatar
Default Voltage question..
immediately after installing an aftermarket headunit (Kenwood), the voltage dropped to between (13.0-13.5). Both battery/alternator are both healthy. I was accustomed to seeing a range closer to (13.7-13.8) while driving. At idle I see around 12 volts. I have to assume the headunit is constantly under load even turned off. What cha think?
Old May 15, 2007 | 10:31 AM
InTTruder's Avatar
AudiWorld Awesome User
Default I opine it is always hot (I have a Kenwood KDC CD/R in the 855). I'm installing ...
a Clarion 675USB HU shortly in the TT.
You have two power leadsd to the HU, and one is always on. Should have some voltage drop on the system when the car is on, although I'd have to look at how many watts you consumed to make that so!
Old May 15, 2007 | 10:33 AM
TTuned's Avatar
I figured so. Thank You. ;-)
Old May 15, 2007 | 10:35 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default A fully charged battery..>>
can be regulated down to a 13.1-13.5 charge rate. Doesn't sound like anything unusual.
Old May 15, 2007 | 10:46 AM
TTuned's Avatar
Thanks Steve. I just worry alot.
Old May 15, 2007 | 11:31 AM
TTinCT's Avatar
Rest In Peace
Default should be minimal.....>>>
i just sprung for a solar charger for the car that runs a 12volt outlet to trickle charge the battery....
After 2 weeks + of sitting while on vacation, she fired right off.....Worth the 26$ IMO for cars that sit.
Old May 15, 2007 | 11:46 AM
InTTruder's Avatar
Agreed!
Vicl
Feb 13, 2018 02:36 PM
BillBoost37
Aug 17, 2015 06:53 AM
LiTTespeed
Feb 20, 2006 08:16 AM
crabman
Feb 19, 2005 05:10 PM
Ego
Jan 19, 2001 08:43 PM
