ESP warning indicator stays on after resetting, ever had this problem?
Old May 15, 2007 | 10:30 AM
deserTT's Avatar
New Member
Default ESP warning indicator stays on after resetting, ever had this problem?
Is it likely to be a sensor or the brains behind the system. I'm not driving that aggressively.
Thoughts appreciated.
Old May 15, 2007 | 10:33 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Sensor, yes.....you'll need to VAG it and get the fault code..
Could be a lateral or longitudinal sensor..
Old May 15, 2007 | 11:21 AM
deserTT's Avatar
New Member
Default Re: Sensor, yes.....you'll need to VAG it and get the fault code..
the codes are 00526 brake light switch and 01423 lateral acceleration sensor
Old May 15, 2007 | 11:26 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default There ya go...>>
You've got to replace the parts for the codes to go away permanently..
Old May 15, 2007 | 12:11 PM
deserTT's Avatar
New Member
Default Re: There ya go...>>
is this straightforward or a dealer type of fix?
Old May 15, 2007 | 12:19 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Longitudinal/lateral install notes..>
<ul><li><a href="https://forums.audiworld.com/tt/threads/431500.phtml#1556568">https://forums.audiworld.com/tt/threads/431500.phtml#1556568</a</li></ul>
Old May 15, 2007 | 12:20 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Brake switch notes...>
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1389909.phtml">https://forums.audiworld.com/tt/msgs/1389909.phtml</a</li></ul>
Old May 15, 2007 | 12:21 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
See notes above...Looks like both under the dash. Not hard
 Pouria Savadkouei
 Michael S. Palmer
Old May 15, 2007 | 12:33 PM
deserTT's Avatar
New Member
based upon the cost of repairing I might as well learn to live with the light on.
Old May 15, 2007 | 12:40 PM
Scenic Driver's Avatar
... and without ESP? Do your brake lights work?
