Replacing stock catalytic converters with...
Old May 15, 2007 | 09:39 PM
Kenghh's Avatar
Default Replacing stock catalytic converters with...
Miltek high flow ones. Is there anything I should pay special attention to when removing the stock ones?
Thanks!
Old May 16, 2007 | 03:55 AM
TTinCT's Avatar
Rest In Peace
Default the bolts may be a bit rusted....>>>
and you need a fresh gasket...other than that..enjoy!
Old May 16, 2007 | 05:21 AM
Scenic Driver's Avatar
Default 2nd that >>>
I almost needed a torch for the bolts on the center clamp when I did my exhaust (no air tools in the parking lot :-().
Old May 16, 2007 | 05:44 AM
Kenghh's Avatar
Default Thanks guys! What about when removing O2 sensor?
Is it better to remove sensors themselves from the cats or undo the wire harness connectors?
Old May 16, 2007 | 05:51 AM
TTinCT's Avatar
Rest In Peace
Default those sensor are very sensitive>>
does not take much to damage them...personally, i have broken two by dropping them..(yeah..klutz here!)....
I would remove the connector on the harness, then install the sensor on the new cat if you are working in a tight space...if you are on a lift then either way works...
Old May 16, 2007 | 06:05 AM
Kenghh's Avatar
Default Awesome! Thanks much for the suggestions! >>>
Is it safe to clean the sensors with electronics cleaner spay?
Old May 16, 2007 | 07:07 AM
TTinCT's Avatar
Rest In Peace
Default yes.....but with o2 sensors>>>
you need to use a non-oil based cleaner.....so a good CRC cleaner should work fine....
A couple of links to o2 info..
http://www.gnttype.org/techarea/ecmsensors/O2sensors.html
http://forums.bimmerforums.com/forum/showthread.php?t=324738
Old May 16, 2007 | 07:15 AM
Kenghh's Avatar
WOW. Really helpful! Thanks again, sir!
 Pouria Savadkouei
 Michael S. Palmer
Always Overcharged
Dec 28, 2005 05:39 AM
mt6127
Sep 3, 2004 07:20 AM
tonster799
Jun 20, 2003 08:52 PM
NJRickD
Sep 21, 2002 10:04 AM
TTEBERTT
Jan 5, 2002 01:39 PM
