oxygen sensor, universal yay or nay?
Old May 17, 2007 | 06:32 AM
superg3's Avatar
Default oxygen sensor, universal yay or nay?
I can solder but how do you know which wires correspond to the one on the oem harness? Are they color matched? I have a 2000 atc, I believe it's a 4 wire front and back.
I have 1 fault code oxgen lamda sensor- internal resistance too high.
Thanks
Old May 17, 2007 | 06:40 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Yay...>>
They are color coordinated. 2 white wires for the heater circuit, Gray and Black (signal) for the other 2..
Old May 17, 2007 | 07:09 AM
SereniTTy's Avatar
I've doen just fine with Universals in mine. And at $58 each, the savings was worth some soldering.
Old May 17, 2007 | 07:57 AM
polishadonis's Avatar
Did you put in two new ones for the dp install? Or did they go bad on you once?
vtraudt
Jul 18, 2011 11:00 AM
mofologic
Aug 24, 2005 01:25 PM
qfrog@work
Mar 22, 2005 12:48 PM
DanA100
Misc. Models Discussion
Jul 15, 2001 10:47 AM
