Please help Vag Codes
Old May 17, 2007 | 10:16 AM
element2050's Avatar
New Member
Default Please help Vag Codes
Seems like its every month something goes wrong. All I do is fix things. My latest issue was My drivers side window wont go down ne more. Now I can't get over 5PSI and before this happened it was gutless, I just pulled theses codes-
VAG-COM Version: Release 311.2-N
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 8N0 906 018 K
Component: 1.8L R4/5VT G 0003
Coding: 06710
Shop #: WSC 13878
TRUWT28N611047807 AUZ5Z0A4290058
3 Faults Found:
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-00 - -
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
Readiness: 0000 0000
Address 08 -------------------------------------------------------
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
Thanks for any help.
Old May 17, 2007 | 10:24 AM
Scenic Driver's Avatar
Default ...
17521 = Bad 02 sensor or bad wire/contact
17964 = boost leak, pressure test the car
Old May 17, 2007 | 04:16 PM
GoTToGo's Avatar
Junior Member
Default On the brake switch code, see if the brake lights come on or...
try the cruise control. If they don't work, you need to replace the brake switch (under the brake pedal). Relatively easy repair.
Old May 17, 2007 | 04:27 PM
chaugner's Avatar
New Member
Need a new brake switch for sure (just replaced mine for the same reason) .. prob new O2 as well
nebraskaa4
1.8T Discussion
Aug 13, 2013 08:33 AM
ttmxp
Jul 13, 2007 06:34 AM
the senator
11
Dec 24, 2003 11:47 AM
EasTTcoasTT
VAG-COM Discussion
Aug 10, 2003 03:07 PM
