please help -- car won't start >>
Old May 18, 2007 | 06:02 PM
andrew.tt's Avatar
Default please help -- car won't start >>
it will crank forever. it's just not catching.
i smell gas, so i think i'm getting fuel. the juice is good too.
it was cold and rainy today in boston.... the car has been having hard starts for a couple weeks now. sometimes it will choke and die, and start right up on the second try. but, this is the first time it won't start at all.
any advice would be appreciated - how do i go about trouble shooting?
Old May 18, 2007 | 06:44 PM
SparTTan's Avatar
Can you check for codes with a vag-com?
Old May 19, 2007 | 03:25 AM
TTinCT's Avatar
Rest In Peace
Default clogged fuel line???? >>>
maybe not getting enough pressure....
Old May 19, 2007 | 04:09 AM
fredfromny's Avatar
Default Start with the plugs. Dry spray the boots then pull them if that doesn't work.
You may not even get codes.
Good luck.
Old May 19, 2007 | 07:30 AM
andrew.tt's Avatar
Default just did that. still no-go. i really don't want to have to get it flat-bedded.
the plugs were pretty fouled - probably from all the starts. i'm also running pretty rich cause they were very black.
do i try brand new plugs?
andrew.tt's Avatar
hey hans. how would i fix/test for this?
andrew.tt's Avatar
no codes.
Old May 19, 2007 | 07:57 AM
TTinCT's Avatar
Rest In Peace
Default Well..there are two fuel filters on the TT>>>
most only replace the one near the tank....i would start with those as it is always possible one is clogged....from there the next step would be to insure the fuel pump is giving you max pressure...On that...the only way i know that i am getting this is that i have a gauge on the pressure side of the fuel rail (for my adjustable FPR)...
One symptom with the first adjustable i had is that the motor would just spin or start, run rough...then stall. Turns out the FPR was bad...but that is rare...
Last question....is it spinning really freely? Like timing belt broke freely? Trying to get an idea...
 Pouria Savadkouei
 Michael S. Palmer
Old May 19, 2007 | 08:05 AM
andrew.tt's Avatar
Default i had replaced the fuel filter a few months ago >>
just had the timing belt done. i don't think it's spinning freely. sometimes it sounds like it's trying to start, but it "chokes" out.
Old May 19, 2007 | 08:18 AM
kodeTT's Avatar
Elder Member
Default fuel pump is my guess...happened to me awhile back.
it would crank and crank...but not catch like you said. i have a fuel guage in mine now, so i can tell if there's pressure in the line. should be easier for me to tell next time.
