Name that leak! :-(
Old May 18, 2007 | 06:04 PM
::blinde::'s Avatar
Junior Member
Default Name that leak! :-(
Ummm...changing the oil tonight and noticed this...
<img src="http://pictureposter.audiworld.com/119989/dsc00662.jpg">
What is leaking and what am I looking at to fix it?
Old May 18, 2007 | 06:08 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default ooops.....>
Yellow Brake fluid? That would be a leaking clutch slave cylinder if that's what it is. Check your master Brake reservoir and see if you're loosing fluid!
Old May 18, 2007 | 06:09 PM
ShafTT  (aka CrafTT)'s Avatar
Member
Well, thats the tranny. So its tannish in color. Maybe oil
Old May 18, 2007 | 06:16 PM
Member
Default I know the clutch line connects with a C-clip. Maybe check that.
If not, there is a 10mm bleed valve where the line connects. Check that. Also check where Steve said :-)
::blinde::'s Avatar
Junior Member
Default There's fluid in the reservoir, but the front is on ramps so it's not an accurate reading.
I'll check tomorrow when it's not on ramps. My brake fluid is yellow. I hope it's not the slave cylinder...might as well get the whole clutch and flywheel done at the same time, right? &lt;sigh&gt;
Thanks, Steve.
Old May 18, 2007 | 06:19 PM
::blinde::'s Avatar
Junior Member
Oooh...maybe that's it. Where does the clutch line connect at with a C-clip? Where's the bleeder?
Old May 18, 2007 | 06:20 PM
Member
It sits on top of the tranny. Almost under the battery. I'll look for some pictures
Old May 18, 2007 | 06:23 PM
::blinde::'s Avatar
Junior Member
I had a brake fluid flush 2 months ago...maybe they jacked something up?
 Pouria Savadkouei
 Michael S. Palmer
Old May 18, 2007 | 06:24 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Pressure bleed?
Could have toasted the seal in the slave cylinder..
Old May 18, 2007 | 06:27 PM
::blinde::'s Avatar
Junior Member
Default Good question...I didn't ask. It was an indy shop that only works on Audis and BMWs...
I would hope that they would do it correctly...but you never know.
