Major Brake Problems, Please Help!!!!!
Time Line:
- Had car washed and detailed looks like they detailed the engine bay as well, my understanding that's never a good thing :-(
- Soon as I got the car back home the fun began
1. Car making a very distinct sound like that of an old gas powered generator coming from the brake reservoir/ boster area.
2. On the guage pod: Traction Control light flickered on/off then stayed on (seemed to be some correlation between the brake pedal), ABS Light on constantly, "Brake" light on, when put in to gear warning sound and light began to flash.
Now here is where it really gets good.
3. Upon rolling off car would not move. Though hand brake was released car responded as if the brake was still engaged (All the while the "gas powered generator" sound still going) Pumped the break a few times-- SOUND STOPPED. Car would then "move".
4. And by "move" I mean like a donkey in high heals - Very little power. AS I moved through the parking lot got through 1st gear then shifted into 2nd (Again very little power with the throttle at 100%)Car just bogged down like trying to roll off the line in 3rd gear -- TURNED OFF traction control-- Car acclerated and performed somewhat reasonably. "Brake" light flashing, ABS and Traction Control both solid on the guage pod
5. Got back to the driveway checked the break brake reservoir (good to go) check the boster connections also good to go. No brake fluid anywhere.
Neither battery nor alternator ever changed- Car has 71294 miles on it.
Let me know what you guys think, Thanks
To me it sounds like they get some component seriously wet to the point it is shorted. As Schwing said, could be the ABS or could be they got water into the intake too....hard to tell...but the ABS light is a good indicator....
I would try to get it dried out....then see what happens...if you have a VAG-COM, that might help too...
Good luck...
