Cold Air Ports?
Old May 19, 2007 | 11:40 AM
element2050's Avatar
New Member
Default Cold Air Ports?
I was just helping my buddy work on his TT and now that he has the headlight washers out I notice you might be able to run a hose to each of them to provide cold air to the intake. Ne one ever try this?
Old May 19, 2007 | 12:08 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Won't work....
Not without cutting a bunch of structural plastic under the headlight. If this was possible it would have been done YEARS ago. I wouldn't do it.
Just remove the gasket between the hood and firewall for an 18 degree reduction in engine bay temps..With a P-Flow, you NEED it!....:-)<ul><li><a href="https://forums.audiworld.com/tt/msgs/1574191.phtml">Cheap and easy</a></li></ul>
Old May 19, 2007 | 12:10 PM
GorTT's Avatar
Default and of questionable appearance >
just use the lower driver's side smic intake opening - Steve's got volumes on that.
Old May 19, 2007 | 12:12 PM
New Member
Default Where is this gasket?
Between the hood and firewall? My car gets really hot I need to cool it down. BTW just bought a pressure tester! I can run that with the boost machine still installed right?
Old May 19, 2007 | 12:18 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default This gasket...>
and yes, the BM has no impact on a pressure test.
<img src="http://images20.fotki.com/v357/photos/7/7305/4257627/IMG_0964-vi.jpg">
Old May 20, 2007 | 09:16 AM
New Member
Default is that good idea though?
are you talking about just the rubber piece or the whole thing (ie. like im getting to the ecu)
Old May 20, 2007 | 09:23 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Just the rubber piece....Cooler is better
Old May 20, 2007 | 09:28 AM
New Member
I sent a email but do you still have the trim stuff?
 Pouria Savadkouei
 Michael S. Palmer
Old May 20, 2007 | 09:33 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Backatya!
dmaclaren
3.2 24v VR6
Jan 7, 2013 06:19 AM
starting ...
Oct 29, 2007 08:32 AM
AggregatVier
41
Sep 27, 2004 06:35 PM
Silver4ringer
Aug 24, 2001 01:22 PM
EighTT
Jan 30, 2001 09:36 AM
