How many out there with Eibach pro-kit springs had to add the alignment kit to...
Old May 19, 2007 | 01:03 PM
A6sport's Avatar
Default How many out there with Eibach pro-kit springs had to add the alignment kit to...
get the camber into spec? Did a search and found the kit was needed only if the drop was more than 1.5 inches -
Old May 19, 2007 | 01:12 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default You'll need it....>
1/2 kit will barely get you to an acceptable setting. Full kit recommended if you want full adjustability...Read my findings on this at the link:<ul><li><a href="https://forums.audiworld.com/tt/msgs/1101053.phtml">Here....</a></li></ul>
Old May 19, 2007 | 01:28 PM
A6sport's Avatar
Just what I thought...many thanks -
Old May 20, 2007 | 07:59 AM
oc_tt's Avatar
Any spring options that don't lower less than an inch?
Old May 20, 2007 | 11:33 AM
InTTruder's Avatar
AudiWorld Awesome User
Default I got the CPT LCA going on. I was 'just'.....
in spec, and want to have some adjustability for balancing under/oversteer.
black467
Apr 3, 2005 04:53 PM
DeutschDriver
Aug 18, 2004 11:39 PM
Avants
10
Jun 22, 2004 03:59 PM
seaTTym
Apr 8, 2002 08:06 AM
